arggg! cant keep crank bolt in motor!
the 1st one i thought was my fault.
i hit it with the impact and let it ride. 230ft pd would be a decent guess from past experiences.
2nd bolt was covered in red rtv(all i had at the time)
torqued to 200ft pd with wrench, then hit with an extended breaker bar as hard as i can go.
arp bolt both times.
both have exited the motor.
what gives??
eagle crank and ati damper if it matters.
what gives??
Good advice above and it's what I did back in 2004 when I installed my ATI balancer w/ an ARP crank bolt.
The threads on the bolt and the crank interior need to be very clean, Brake Parts Cleaner works well for this.
Red Loctite on the bolt threads, and ARP Moly Grease under the bolt cap. Torque to spec and you're done.
Use the ARP bolt to seat the pulley,(seeing that it's about 1'' longer) then back it out use a gm bolt with red locktite torque 230-250 then try to turn 90* and you're good to go
