Aeroforce Interceptor usable parameters
Old 06-16-2009, 07:06 AM
ls1owner4life's Avatar
Default Aeroforce Interceptor usable parameters
Question about the Aeroforce interceptor; what parameters are usefull without additional sendors. I understand it displays something like 75 readings but how many will display one the 02 camaros PCM. Fuel pressure, oil temp and pressure, wideband AIR/FUEL ext...?
Old 06-16-2009, 07:28 AM
BIG_MIKE2005's Avatar
Well if your just gonna use the gauge itself without adding additional sensors & modifying the harness then you can just use the buttons on the face to scroll thru & see what it'll read. I have mine set to knock retard & coolant temp. Seems very accurate so far.
Old 06-16-2009, 09:24 AM
Grifter's Avatar
AerForce has a list on their website of all the parameters that can be shown. I'm pretty sure it will not read AFR, oil pressure or oil temp without adding a sensor or modifying something.
Quick Reply: Aeroforce Interceptor usable parameters
