kooks header install on a 408....HELP!!!
Old 06-22-2009, 11:13 PM
gmmusclecarman's Avatar
Default kooks header install on a 408....HELP!!!
Ive spent this whole afternoon trying to install my Kooks 1 7/8 headers on my 408. The passenger side went in no problem but now the drivers side is not going in no matter what. Ive tried the search and did all the methods people suggested other than major things. I havnt tried lowering the k-member or pulling up the motor. But I really dont want to do those things because ive spent the last few days getting them into place. I think part of the problem is getting the car high up enough to get the header in at the right angle. One guy was saying he just turned the flange to a 90* angle facing the ground and just shoved it up and into place but i cant seem to get that to work. It looks like you can get it in from the top if you take out the steering shaft. Im not sure how to take that out and i didnt want to break it. I also have Spohn solid motor mounts and nothing a but a bare longblock in the engine bay. It just seems like everyone has their own way of doing this and none of those methods are working for me.
What do you guys think?
Old 06-23-2009, 08:23 AM
c'mon guys
Old 06-23-2009, 08:26 AM
Kleeborp the Moderator™
MeentSS02's Avatar
That must have been my post where I said you could turn it 90 degrees and get it up into place - keep in mind that when I say that, it is possible, but it does take some persuading to get it up there.
Removing the steering shaft isn't too bad...you should be able to see a couple of bolts. Loosen those, and it'll slip off.
Old 06-23-2009, 08:35 AM
yep as a matter of fact that was you. when i remove the steering shaft does it just pull up and out of the rack? I was trying this before and couldnt get it out but didnt want to break anything. If i did this would it be possible to go in from the top. it is not getting in the way from the bottom. What I also think would help is getting the car high up enough to get it in at the right angle. Do you have and safe ways of lifting with a normal jack and jack stands? I suppose i could try putting some wood blocks underneath the stands.
Old 06-23-2009, 08:47 AM
blk00ss's Avatar
Your not going to break that steering shaft. There is a bolt at the top and one of the bottom of the shaft. Both must be taken out then you can slide the shaft up and it will pop out. It will probably take a little persuasion with a hammer to get it to move. It's hard to explain exactly how to do it. But if you have gotten this far by yourself you can definately do this.
Old 06-23-2009, 09:14 AM
outkast6991's Avatar
if your running a stock k member start with the header straight up and down in front of the hump that sticks out towards the oil pan. you should be able to go straight up then rotate in. i tried for a while before i figured out i needed to start in the front hole so to speak. good luck man
Old 06-23-2009, 09:27 AM
is the key here just to get the car up extremely high? I was trying this method but was still having trouble with ground clearance which is probably why i couldnt get it in.
Old 06-23-2009, 09:41 AM
high enough that you can get the header almost straight up and down in the hole. i used a set of truck jack stands. the bottom of the rocker panel was about 24" of the ground in the front and i had the back end up as well(about 18")
Old 06-23-2009, 09:46 AM
damn thats pretty high, ill see what i can do.
Old 06-23-2009, 10:00 AM
MeentSS02's Avatar
I had to use a truck jack stand as well...it requires a fair amount of clearance.
Old 06-23-2009, 10:26 AM
i wanted to thank you for the tip. i was under there cursing like crazy till i found your post then i went back out and it slid right in. thanks man
Old 06-23-2009, 11:25 AM
MeentSS02's Avatar
Glad it helped...it is a very nice trick to know with the Kooks headers.
Old 06-23-2009, 11:27 AM
Banned Village Idiot
LS1BLKSS's Avatar
its a bitch!!! but it can be done just take your time... if you have some one to help you let them try... i was having a very hard time doing it and my buddy was with me and i let him try and he pushed it in like nothing!! its luck im telling yoU!!!!!!!! lol
Old 06-23-2009, 01:31 PM
PAGregSS's Avatar
Did you already cut the little casting square off the block that sticks out just above the oil filter? Cutting that off with a cutoff wheel or sawzall will help you a ton. It's small, but it's in a pain-in-the-*** location.
Old 06-23-2009, 02:21 PM
no i have not, i dont have anything to cut it with.
Old 06-23-2009, 03:26 PM
this is impossible. I think im just going to pulling the engine again.
Old 06-23-2009, 03:52 PM
skeels's Avatar
I think i may have taken the 4 bolts out of my tranny crossmember and lowered the tranny down just a bit, enough to make the motor move and it was easier when i installed my tsp 1 7/8" headers
Old 06-23-2009, 11:40 PM
Ok i just cant do this. I have tried every possible way i can do and i just dig myself into a deeper hole. I really need somebody to come and help me with this. anybody in the chicago area available this week?
Old 06-25-2009, 01:28 AM
FINALLY GOT IT!!!! just ended up pulling the engine. 3 days to install headers. damn....
