Check Gage Light After New Alternator install,Why?
I had to put a new Alternator on my 408 I was around 10.5 on the cars stock gage.I choose to go with a 160 amp alternator do to all the extra's I am running.Got the new alt in and Now I have check Gages light?Why is this because I now have 14.5 v on the gage?
Thanks!
Thanks!
The alternator has a little extra cable that goes on top of it apart from the main cable. It can be easily missed or the plug broken. Also, did you change the cable to a higher gauge? Sometimes this is needed to get the full benefit of the this new high output alternator...thing to consider.
I'm not an expert for sure but I just checked mine tonight. I disconnected it at the alternator and with the key turned on used a meter to check for voltage.
Figuring if I had a beak in the wire it would read 0, but it read between 6-7 volts so I think it should be good. Someone correct me if I am wrong.
John
John
