quick brake questions
Old 06-29-2009, 07:48 PM
98hc4mula's Avatar
Default quick brake questions
I had to replace the master cylinder for the brakes and once I tightening the outer line I noticed that fluid is zipping through there. I can see a big leak once I apply more preassure to the breaks.
is there something that I can use to seal this line?
the threads seem ok and it comes in and out fine. Its just not sealing.
HELP, Im in the process of doing this.
thanks
Old 06-30-2009, 03:58 AM
DaddySS's Avatar
Remove the connection - does the end of the line look OK?
