Modification to Corvette LS1 sheet metal exhaust manifolds
Old 07-04-2009, 05:30 AM
grobb284's Avatar
Default Modification to Corvette LS1 sheet metal exhaust manifolds
Has anyone ever cut off the EGR tube on top of the sheet metal exhaust manifolds to clean them up?
If you cut the tube off, is the manifold flange flat underneath it, or is it a cavity for the tube?
Any cautions in welding the openings up in the header tubes? Are the header tubes stainless or carbon steel?
Post some pictures please if you have made this modification.
