L92 injectors in LS1 or LS2 manifold?
Will L92 injectors fit a LS1 intake manifold? How about a LS2 manifold? I have a L92 crate engine that I'm planning to put 317 heads and a car manifold on (for low rpm torque; nothing above 5000 rpm). I'd like to use the injectors if possible.
Thanks
Thanks
they will fit a LS1 and a LS2, but you will have to change the injector Orings to the proper sizes for the respective manifolds. Also, they are about a 1/8" shorter than LS2 injectors in heigth though, so you may need to watch your fuel rail clearance, or slightly bend the mounting tabs upwards to snug the rail up to the intake tighter for proper injector seal. The L92 / GEN IV truck injectors are alot smaller than LS2 injectors though, and cant be resized. I have a set of new LS2 injectors if you need some, im looking to sell. PM me if interested
