Guys with cat'ed Y-pipes
Old 07-14-2009, 03:35 PM
TooLateVTEC's Avatar
Default Guys with cat'ed Y-pipes
Where'd you buy it or did you have one fab'd up?
Just got my Hooker LT's this morning and looking for one of these as my area might have emissions soon. Its already in the next county.
Thanks
Old 07-14-2009, 03:45 PM
LS199CAMAROZ28's Avatar
I'm having mine fab'd up friday and taking my TSP duals off. Pacesetter headers, magnaflow 59959 cats, flowmaster merge. Also having v-clamp welded on at the headers and after the merge. Magnaflow catback put on as well. I can't wait.
Old 07-14-2009, 07:03 PM
corvet786c's Avatar
I bought my catted y from TSP high flow car sound converters. Then I had a local shop moddify the 2 pipes merging into a 4 inch flowmaster merger. Should add about 10wrhp.
Old 07-14-2009, 09:28 PM
slayerized6's Avatar
i got the built catted y pipe from TSP. not to happy on the fitment, but i really dont think it can be made much better; hangs wayyyy to low.
Old 07-15-2009, 11:06 AM
You dont happen to have any pics under your car do you? B/c I just bought that y-pipe yesterday evening for mine.
Is it all welded up when it shows up or is there some adjustment in it?
Thanks for the reply's.
Old 07-15-2009, 02:56 PM
ill snap a picture and post it in a few minutes. the y pipe comes in pieces; the 2 cats themselves and then 4 or 5 pipes that need to be clamped or welded together. i had my headers/y pipe installed by a non-sponser shop familiar with fbodies. they claimed they tried rotating each section of pipe to try and get the best possible ground clearance. i even took a good look myself; theres no way you can make it better. i wouldnt say its a horrible with ground clearance, but if your lowered, your in for some problems.
pics are to come within the hour....
Old 07-15-2009, 03:06 PM
NJNETSFAN's Avatar
TSP catted y setup here....fitment sucks. Spend the money once and do it right. TSP's setup works, but for the $$$ your spending, it should fit better and simply doesn't.
Old 07-15-2009, 03:07 PM
pic one- as you can see, the exhaust only clears 2/3 of a soda can.
pic two- after the collector on the headers, the y pipe MUST make a 1 to 2 inch dip because of the design of the chassis.
i forgot to take a pic of this, but if you STAND 15 feet away from the car, you can actually see the y pipe slinging downwards
Attached Thumbnails Guys with cat'ed Y-pipes-dsc00591.jpg   Guys with cat'ed Y-pipes-dsc00594.jpg
Old 07-15-2009, 03:08 PM
i was trying to go that route, but no one else makes a catted y that works with pacesetters.
Old 07-15-2009, 03:56 PM
LS1Tech Premium Sponsor
Trevor @ Texas Speed & Perf.'s Avatar
Our TSP y-pipe has been redesigned. The pics shown are of our old design. We have changed over to a bullet-style cat that will allow for even better ground clearance, and the fitment has been improved upon as well. I've posted a few pics for everyone to check out. The new design is in stock and ready to ship!
__________________
Old 07-15-2009, 04:17 PM
Slayer your the man for posting the pics, thanks for that man.
Trevor, im not sure if im getting the new one or the old one...guess ill see when it gets here. Bad thing is is that I didnt get it from you guys, got it somewhere else b/c it was cheaper before shipping. So im sure its the older design, thanks for posting the pics of the new design though...rub it in why dont ya! haha, just kidding.
Old 07-15-2009, 05:55 PM
Jason 98 TA's Avatar
Both designs will clear pretty good with a good install. Take your time putting it together before tightening the clamps & you'll have a nice tight install! The new cay y pipe has better clearance with our new high flow small diameter cat!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 07-15-2009, 06:48 PM
got milk??'s Avatar
I took my Pacesetter Y pipe because of the pressed section and custom fabbed some cats in. I have not found a better clearing setup yet. I am eager to try the new texas speed though!
Old 07-28-2009, 12:14 AM
metalmechanic's Avatar
kooks
