New T/A owner...got a question.
Old 07-18-2009, 05:32 PM
ta-stanger's Avatar
Default New T/A owner...got a question.
Hey guys. I picked up a Pewter 02 T/A WS6 w/ 12k miles this week. I Love this car! Its got a hurst short shifter, muffler delete, and K&N open filter.
Just got a question...the guy told me that they put LS6 heads on a certain number of T/As and that this was one of them. How can you tell if they are LS6 heads?? Is there a certain number that i should be able to see??
Thanks guys. Pics will be coming soon.
Old 07-18-2009, 05:47 PM
99 Blue Bird's Avatar
i believe you can see the casting number on the head. i think mine says 853 but they are stock casting ls1 heads. but i have never heard of that before.
Old 07-18-2009, 05:49 PM
now that i have read your post again and i see that your car is a 02 i think he ment to tell you that a LS6 intake manifold came on the car not the heads.
Old 07-18-2009, 05:55 PM
ta-stanger's Avatar
The casting number is 241?
Old 07-18-2009, 05:57 PM
ta-stanger's Avatar
He said the LS6 intake and heads?
Old 07-18-2009, 05:58 PM
2001NBMZ28's Avatar
Yeah 01 and 02 came with the LS6 intake and no EGR. Heads should have 241 stamped on them. A small percentage came with a LS6 block, maybe that's what he was referring to. The casting number is located on the drivers side left hand deck above the transmission flange (12561168).
Old 07-18-2009, 06:02 PM
ta-stanger's Avatar
Ok damn. Thanks for lettin me know...i hate not knowin for sure whats done to a car.
But what is a cheap way to get some power outta these cars? Besides a lid? Does tuning help the LS1s a lot. Sorry for all the questions...ive only been around stangs my whole life. Now i got both and need to learn about this car lol.
Old 07-18-2009, 06:58 PM
thats cool i learned something new. i didnt know they came with the heads as well. thats pretty interesting. anyways yea tuning helps the car. i would buy a set of long tubes and the y-pipe and a cat back first before you tune it though. to me its not worth paying a couple hundred dollars to have your car tuned than have to take it again after doing the headers and exhaust. im sure you will be very happy with the car after a header install
Old 07-18-2009, 07:29 PM
2001NBMZ28's Avatar
They didn't come with LS6 heads, 241's started appearing on LS1's in late 2000.
Old 07-18-2009, 10:28 PM
99Ls1fever's Avatar
241 Heads are an LS6 casting. They came on 01-02 F Bodies. They are a great flowing stock head
853's came on 98-00 F bodies and are a shitty head.
Old 07-18-2009, 10:59 PM
02BLACKTAWS6's Avatar
Just kidding.
Old 07-18-2009, 11:08 PM
97ta383's Avatar
241 and 853 are the same they are both ls1 casting head ls6 casting number is 243 and NO f body came stock with 243 heads some 02s had the ls6 block and all ls1s after 2001 had the ls6 intake so unless someone changed the heads on his car they are ls1 heads not ls6.
Old 07-18-2009, 11:18 PM
99Ls1fever's Avatar
No, 241's are a "LS6 casting head." And The 241's came on F bodies. And Yes LS6 Engines came with 243 Heads, 243's came on LS2's and LS6 Engines. 241's are a LS6 Casting. That doesn't mean they are a LS1 casting. 853's are a "LS1 Casting." Totally Differant.
s346k's Avatar
you are mistaken. 241 is NOT an ls6 cast head. 243 is the ls6 head. also, there is no difference between the 853 and 241 heads. i believe the 241s were sand-cast, whereas the 853s were not. however, the difference in casting process did not increase power.
to the op: start with headers, an ory, the muffler of your choice, and a real tune. that will free up quite a bit of power. my stock 2000 a4 car picked up 9mph (101-110) in the 1/4 from adding headers, an xpipe, and 4x9 magnaflows turned down at the axle, all else being unchanged.
Old 07-18-2009, 11:24 PM
99Ls1fever's Avatar
Are you kidding, I have seen 15 hp gains at my dyno shop from switching a 853 and a 241 head. 241 Heads are LS6 Casting. There is no differance between them and a 243. They Flow exactly the same.
Old 07-18-2009, 11:27 PM
s346k's Avatar
no, i am not kidding. i think you have casting numbers mixed up. you will see 0 going from 853 to 241. however, going from 241 to 243 you should see about 15whp.
so you're telling me that the 99 ta in sig that traps 108 now with a lid, ory and flowmaster muffler will go 112 just by switching from 853 heads to 241s? as i mentioned earlier, you sir, are mistaken.
Old 07-18-2009, 11:31 PM
99Ls1fever's Avatar
Whatever man. The 241's are a better head and Flow better than the 853's that is common knowledge. Sorry but I have seen it in person. When you can say that I will take your word for it. I agree the 243's are a good head. I have two sets in the garage. There is no differance between them and the other set of 241's that are in my hand. The 853's are different.
Old 07-18-2009, 11:36 PM
99Ls1fever's Avatar
853 was used on 99-00 LS1 engines.
241 was used on 01-04 LS1 engines.
They both have a 66.67 cc combustion chamber (10.1 CR), 200cc intake runners on the 853, 241s have a different design in regards to their intake runners that allows for more efficient air flow, more velocity.The 241 has 210cc intake runners and 70cc (round) exhaust ports.
The 243 head is the 01+ LS6/LS2 head.
It has a smaller 64.45cc chamber for more compression (10.5 CR on LS6), 210cc intake runners, and 75cc D-shaped exhaust ports.
All three came with 2.00" intake valves, and 1.55" exhaust valves.
Of the three, the 243 (Z06) head is the most desirable for flow, and is the most popular base for further porting/modifying. Not many people mess with porting LS1 heads anymore.
And FYI for the ones you didn't mention...
5.3 truck heads (casting #862 and 706) are also a very popular base casting for porting/modifying, due to their even smaller (61.15cc) chamber size which raises compression when used on a LS1/6 engine..
6.0 truck heads (casting #317) are popular heads with the forced induction crowd, as they are basically the same as 243 heads, but with larger 71.06cc chamber size, which lowers compression when used on a LS1/6 engine.
Old 07-21-2009, 02:09 PM
FEDUP's Avatar
Yep thats what I heard.
Old 07-21-2009, 02:58 PM
Marc 85Z28's Avatar
Read the forum. I guarantee you will find your answers faster than someone can reply to this thread. No need to post the same question 1000s of others have asked before.
And to 99Ls1fever: 241 and 243 heads appear the same to you!? Are your eyes not open, or do you just not know what you're looking at?
