bracing required for solid motor mounts??
Old 07-24-2009, 01:39 PM
WickedSuperSport's Avatar
Default bracing required for solid motor mounts??
my friend was telling me that you need to install sub-frame connectors and all that before you put solid mounts on, or you will tweak or crack your frame. is this is any way true?? Also, is it bad to run solid motor mounts and the stock rubber tranny mounts???
Old 07-24-2009, 01:45 PM
Kleeborp the Moderator™
MeentSS02's Avatar
If it was my friend, I'd smile, nod, and happily install my solid motor mounts without subframe connectors.
As for running the rubber transmission mount - that I probably wouldn't do on my car. The transmission has enough mass behind the engine and is far enough away from it that I would want it a little better supported - at least with a poly motor mount since it has less give to it than the rubber piece. But that's just my back-yard engineering at work - I don't have solid motor mounts, so I can't say what you should do about the trans mount since I have no experience with them.
Old 07-24-2009, 01:53 PM
danhr's Avatar
sfc's aren't necessary but always a good idea in a uni-body car.
and I would run the rubber tranny mount with solid motor mounts.... That's what I have on my car right now. a stiffer tranny mount might make a little bit too much vibration.
Old 07-24-2009, 02:00 PM
cool. thanks guys, I knew he was full of it, just wanted to make sure haha.
Old 07-27-2009, 11:00 PM
metalmechanic's Avatar
i would use the poly tranny mount also, i do
Old 07-27-2009, 11:31 PM
SHovV's Avatar
solid MM w/ Poly Trans mount
