stock lid
Old 07-25-2009, 12:37 PM
JTSLP559's Avatar
Default stock lid
is there any mod that can be done to the stock LID? smooth it out? anything like that?
Old 07-25-2009, 12:47 PM
01ssreda4's Avatar
I believe it has baffles that can be smoothed out inside of it. Im not for sure bc I have never seen a stock lid in person.
Old 07-25-2009, 01:29 PM
JTSLP559's Avatar
lmao yea this is my first stock lid... first stock lsx car also haha, dont have the funds for the SLP lid so i figured i own a dremel so why not screw with it.
Old 07-25-2009, 01:36 PM
streetassasin's Avatar
I have a slp for $70 shipped
Old 07-25-2009, 02:32 PM
JTSLP559's Avatar
hm... tempting.. pics? is this the best lid for these cars? does it really make the power it states?
Old 07-25-2009, 02:46 PM
Pm me a email or cell num I can send pics to
Old 07-25-2009, 03:01 PM
ms4z28's Avatar
There is no real power difference nothing that you'll ever feel anyways and In my opinion the slp air lid looks the best stock is ugly
Old 07-25-2009, 03:16 PM
TheBlueKnight's Avatar
If you have absolutely no money I would dremel off the baffles but if you compare a stock lid to an aftermarket lid, the neck is a huge part of the upgrade. The stock one is oval and kind of bottle necks. The aftermarket ones are just a huge round circle all the way to the maf. I would just save up $100 and buy an aftermarket one.
Old 07-25-2009, 07:05 PM
DSGB_4_life's Avatar
I cut the baffles off my stock lid and then sanded it down then filled in the two wholes in the silencer wing. and cut the plastic under the filter that covers the gap to the radiator. works great.
Old 07-26-2009, 01:39 PM
JTSLP559's Avatar
ok got the lid smoothed out and all the nasty baffles cut off, are those square cutouts stock? all my other ls1s were modded before i purchased them, also.. that hose is comin from my air pump just sittin there sucking air? should it be connected to anything? what the hell.. could this be why im not passing smog?
[IMG][/IMG]
[IMG][/IMG]
Old 07-27-2009, 12:56 AM
JTSLP559's Avatar
cmon guys! all of you have ls1s and have no clue what that is?!
Old 07-27-2009, 01:03 AM
MelScrilla's Avatar
the slp lid comes with the whole to reconnect it. otherwise they make little K&N filters to go into that hose.
http://www.ws6project.com/user_stor/...roducts_id=538
Old 07-27-2009, 01:14 AM
JTSLP559's Avatar
ok but where does that hose go? i took my stock lid off today to take the baffles out of it, then noticed that hose tucked by the abs and sucking air..
Old 07-27-2009, 01:22 AM
MelScrilla's Avatar
"Required for the AIR breather tube which you will disconnect from your stock lid. After installed, it tucks away nicely behind your proportioning valve."
right from the link.
Old 07-27-2009, 12:48 PM
JTSLP559's Avatar
ok so its fine sitting there? sucking air?
Old 07-28-2009, 01:04 AM
JTSLP559's Avatar
I could not find anywhere this hose connects to! I need help! 3rd attemp failed on passing smog.
Old 07-28-2009, 11:21 AM
MelScrilla's Avatar
thats pretty much what it does when it's connected to the lid, suck in the filtered air from the lid to the Air system thats connected to your AIR pump underneath your headlight. Look for that other big black hose running over the drivers side wheel well, because thats going to the same place.
where i live i dont worry much about passing smog so maybe someone else could help you more.
are you throwing any codes?
Old 07-28-2009, 11:31 AM
JTSLP559's Avatar
i cannot find anywhere on the lid where the hose connects though?.. i dont see any where on the lid it would go... i cant find pics or diagrams anything. nope. no codes
Old 07-28-2009, 11:37 AM
BigBirdLS1's Avatar
That hose goes to your AIR pump. The pump I'm gussing is still there inside the driver side fender well. The should should connect to the right side of your lid. Is there no hole a little bit bigger than a quarter on the right side of your lid? If there isn't and your car is otherwise stock I would be willing to bet that's why you are failing emissions tests
Old 07-28-2009, 10:00 PM
MelScrilla's Avatar
there should be a big hole on the big baffle thing that sits behind you stock lid
