spohn solid motor mounts uneven?
Old 07-25-2009, 09:52 PM
phoenix's Avatar
Default spohn solid motor mounts uneven?
i just installed the spohn motor mounts for my mock up. i notice that the mounts were different sizes. didnt think much of it but know that i have them installed the motor does not sit level. Is this normal or do i have a bent k member or something wrong with the mounts.
Old 07-26-2009, 12:39 AM
RS_SS69's Avatar
You sure you put the short one on the passenger side? When I put some in a customers car for the first time it was complicated at first but its defidently the the shorter one on the passenger side. If they are right then you have a problem and should send them back.
Old 07-26-2009, 01:18 AM
phoenix's Avatar
well i will have to look, they were labeled when i got them. Thanks for the info i am going to check to see where the short one is in the morning.
Thanks
Old 07-26-2009, 07:31 AM
outkast6991's Avatar
how far off are we talking about? mine sits a little higher on the driver side, maybe 1/2 inch
Old 07-26-2009, 12:40 PM
phoenix's Avatar
yea mine is the same way, about 1/2 inch on the driver side.
Old 07-26-2009, 06:45 PM
MTN_Z's Avatar
Mine is the same way also. I wouldn't worry about it if we all see the same thing. I also had to realign the base of the intake that covers the radiator so my lid would line up. Little things like that but not too big of a difference.
Old 07-26-2009, 10:25 PM
00 SiLvEr SS's Avatar
i have a set of energy suspension mtor mounts and i gonna have the same problem or is the motor gonna sit even
Old 07-26-2009, 11:43 PM
only with solids, not the poly's. you should be good
