Installed a set of LPP LTs and offroad Y - PICs and Video
Old 07-28-2009, 09:44 AM
97ramsst's Avatar
Default Installed a set of LPP LTs and offroad Y - PICs and Video
I installed a set of LPP Stainless Long tubes a few weeks ago (they were "polished" but I spent about 20hrs really polishing them before the install.) The look and sound great. I have to say though the fit was pretty shitty...I had to notch the K-Member (a bunch) and even then the y-pipe wouldnt fit together like it was supposed to. I wound up having to load it up with open headers and carry it to an exhaust shop and have them bend the y-pipe some and weld it together to make it work. BUT it sounds and looks great now.
Video of at idle and revving:
http://www.youtube.com/watch?v=FmmNxrlLQRA
Old 07-28-2009, 09:48 AM
Tough Mudder
Hilton's Avatar
You have THE prettiest engine bay I've ever seen. I wouldn't even drive that car.
Old 07-28-2009, 01:52 PM
97ramsst's Avatar
LOL....THANKS, and I don't!
Old 07-28-2009, 02:05 PM
Exeodus's Avatar
Is the same car from High Performance Pontiac?
Old 07-28-2009, 02:14 PM
fbodyman1026's Avatar
Yeah I have LPP's also and mine rub on the k member also. I haven't notched any away to prevent the rubbing but it only happens in reverse so it isn't to big of a deal. The Y pipe hanger is nice also. Be ready for them suckers to change color fast too.
Old 07-28-2009, 02:27 PM
01ssreda4's Avatar
I had to notch mine as well......
Old 07-29-2009, 12:46 AM
VIPRETR2's Avatar
Do you have solid or poly motor mounts? Maybe it's just me but that y-pipe looks close as hell to the underbody. I can't imagine it doesn't make contact. Thanks,
Larry
Old 07-29-2009, 12:51 AM
98ssconversion's Avatar
My y sure as hell does! I dont wanna take a hammer to the underbody though
Old 07-29-2009, 12:58 AM
Frost's Avatar
very nice!
Old 07-29-2009, 07:43 AM
97ramsst's Avatar
YES...that's me!
Mine didnt rub...they HIT. Infact they wouldnt bolt up until it was notched...it wasnt even close.
Larry
Nope, stock mounts and it did hit. I used an old serpentine belt to make a bump stop between the body and y-pipe and it stopped it completely (it sounds ghetto but works perfect and you cant see it at all. With the car being lowered I needed just as much clearence under the car as possible to load and load it out of my trailer....so the closer to the body the better for me.
Well I figured I had cut and modded everything else on the car (including BFH to the wheel wells)...so why not. Actually all I had to bend was a support piece....NOT the floor board. Now its neat and tucked up like it should be with no vibrating or hitting!!!
Old 07-29-2009, 10:47 AM
VIPRETR2's Avatar
Yeah, I actually just saw your post in the appearance section about Ron Jeremy and his relationship with your floorboard, lol. Good idea with that belt, I might have to try that to tuck mine up a little more. It's also refreshing to know that even a gorgeous car like yours has a ghetto mod or two
Larry
Old 07-30-2009, 07:14 PM
do you have poly motor mounts? That would explain a little
