GTO Oil Pan, oil cooler question
I use the GTO pan on my LS swapped car. I ha and sold the Lingenfelter oil cooler adapter because it does not work with the GTO oil pan. I have all my oil cooler parts except the adapter.
I am looking at sandwich blocks and the many flavors, but I know some wont work because there is not enough space to screw the standard style up.
Is anyone using the GTO pan with an oil cooler. If so what oil cooler adapter or sandwich block do you use that works?
I cant see this style sandwich working with this pan, So I need to find out what I can use. I dont think I could even screw this on.
