whats the difference between an escalade high output 6.0 and a regular 6.0???
Old 08-11-2009, 11:37 PM
jb7241986's Avatar
Default whats the difference between an escalade high output 6.0 and a regular 6.0???
i have the opportunity to buy a h.o. 6.0 for 1200 with decent miles. my ls1 has 68,000. should i snag it???
Old 08-11-2009, 11:39 PM
jb7241986's Avatar
to the toppp
Old 08-11-2009, 11:50 PM
LSX Mechanic
Damian's Avatar
You can put Twanty-Fo's on the low output and Thurrty-Too's on the high output.
Kidding..
A 6.0L is a 6.0L. Get it.
Old 08-12-2009, 06:59 AM
SweetS10V8's Avatar
Escalade 6.0L = LQ9
Silverado 6.0L = LQ4 (most of the time)
Old 08-12-2009, 05:15 PM
bczee's Avatar
You can also find the LQ9's in the Silverado also... the LQ9 is about 20 to 40 HP over the LQ4 (depending on which year). Has flat top pistons for higher compression, some of the earlier LQ4 had iron heads.
2002-2006 Cadillac Escalade
2002-2006 Cadillac Escalade EXT
2003-2006 Cadillac Escalade ESV
2003-2007 Chevrolet Silverado SS
2004-2005 Chevrolet Silverado and GMC Sierra Vortec HO Edition Only [Badging on truck](B4V)
2006-2007 Chevrolet Silverado and GMC Sierra VortecMAX Option
Old 08-12-2009, 05:22 PM
LQ9CHEVELLE's Avatar
about a point more compression, floating wrist pins (although most 2006-up 6.0's all seem to have floating pins now), and the cam is a wider LSA than the LQ4. But your probably ditching the cam anyways....so pretty much just a compression difference due to pistons.
Old 08-12-2009, 08:28 PM
yessir's Avatar
payed 1500 for mine with 30,000 miles on it
Old 08-12-2009, 09:39 PM
dwfronk's Avatar
Some have a LQ4 and some have a LQ9, just depends on what vehicle it comes in.
LQ4 has dished pistons and runs somewhere around 9.5:1
LQ9 has flat top pistons and runs somewhere around 10.4:1
Correct me if I'm wrong i think that's what i saw on the compression test.
And i think the 04 and up LQ4 got the same connecting rods as an LQ9 which are stronger.
Quick Reply: whats the difference between an escalade high output 6.0 and a regular 6.0???
