bosch 13111 = crap
bosch 13111 = crap
well i bought those damn 02's that are so conterversial and guess what i got a bank 1 sensor 1 p0133 which is a slow response code, so what should i do, the pass. side one is doing fine then the other day i cleared it and it hasnt come back so im confused, im not getting any insufficient switching codes and now it isnt on. I have the stockers which never threw one code, but are preety old, and some brand new casper extensions should i put them back in,the element is bigger and sticks further in on the stock ones.
I reused my stock O2's with extentions when I installed my LT's with 49k miles on the car. The only code I'm getting is PO420 (insufficient catalyst performance bank 1). Which is from the smaller cats in the aftermarket Y-pipe. No troubles with the O2 sensors. In your case I would definitely try reinstalling the originals. It can't hurt and it may solve your problem without costing you a dime. Thats always a plus.
LS1TECH & Trucks Sponsor
Sometimes they are great, sometimes they are not. Their life is usually short though and I only recommend the GM sensors in performance applications. In alot of daily driver applications the Bosch's are great and I'd run them in my wagon anytime.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
GM / AC Delco
__________________
I'm looking for some today...was getting codes and misfires. Pulled them last night, and I have AFS 98 in passenger side and AFS 97 in driver. Is there any difference besides the harness length? I've got extensions, so if I bought 2 of the same should it matter? I'm thinking of going with Denso and the 234-0425 is more than $20 cheaper than the 234-0487 for the other side, so I'm considering 2 of the 234-0425's.
I wouldn't put new o2's in with your new longtubes. Sometimes new longtubes can foul o2 sensors. I would re-use your stock GM ones for while to see if anything happens before spending the money on new ones.
Pontiacerator
My buddy tried Bosch 13111 and it was codes after a couple of months. My stockers worked out for several months after my LT install, then started throwing codes - at first infrequently, and after time, constantly.
I tried Denso and a Bosch universal. The Denso started throwing codes after month and I tried it on both sides. I couldn't get the Bosch universal to work at all. Waste of money.
I finally gave up and tuned my car to run full-time open loop. It has been working well for several months now.
i just extended the wires on my oem o2s myself... i haven't had any issues or codes thrown so far... i plan to get densos when i get a tune that way i will have fresh o2s in when the tune is done but in the meantime i'll just leave them how they are
i dont understand why some cars like them and others dont i took both bosch's back to AZ and got my money back, my 02 extensions finally came in so i put the stockers back in, gas mileage went way up, back to normal i havent checked to see if im throwing codes but my sotp meter seems dead on!
i had they same problems with mine after install, used same o2 u did, that vette bullshit didnt work either,then installed 2 new ac/delco sensors, reccomended by tuner, GM Tech, works fine now, my motor is stock cept for complete exhaust, he just adjusted timing i believe
