Is the stock f-body maf too restictive
I posted a similar post in the gen lV forums but this one has more traffic. My mods are in my sig. I'm wondering if the stock maf and whisper lid are a significant restriction for my 376 ls3. The TB is a 90mm. I don't want to spend big money to upgrade to an 85mm lid and maf if the gains are going to be minimal. The cam is a 231-243 113+3. I've done a search on mafs but I can't find anything definite. Thanks.
I remember hearing they are good up to like 500 at the crank. The you might be leaving some on the table. But yes, I do think it is pointless to buy a bigger lid (85mm) if your going to keep the stock maf.
100% true, people say the stock is only good to 500 hp because thats all that the sensors are good to. they can only read so high. as for the flow rate of the maf, if u want to do anything above stock i believe in porting it. why have a 90 mm tb or bigger intake, when the maf is like 70? pointless. thats like putting 4" tru duals on your car then right in the middle, putting in a section of 2" pipe
i hear that you can pick up a c5 zo6 MAF for $100. and it is 85mm.
There have been tests that show that the larger lid and MAF on camonly LS1's are good for 5 pounds all across the curve. Im sure on a cam only LS3 you would b looking at 10+
More, "port the MAF" nonsense. You guys should start a club.
Don't port the MAF. As has already been correctly stated in other MAF related threads, if you port the MAF, it will no longer read airflow accurately. There is no linear scaling that can be used to predict the resulting airflow after porting. Stock MAF's will read up to 512 g/s airflow. It's a measuring instrument. There is also the option of removing the MAF & running speed density.
A good option is to go to an 85mm MAF & de-screen it, then have the MAF table re-scaled. 85mm MAF's max out @ 11250 Hz, where the stocker maxes out @ 12000 Hz. Both MAF's scale out & 512 g/s airflow. Reason the guys don't like the 85mm is usually because they didn't have the table re-scaled or they ran out of frequency & didn't adjust the highest few columns to equal the higher airflow @ the lower measured frequency.
If your LS3 is not moving more than 512 g/s, then an 85mm de-screen & re-scaled MAF will do the job for you. If you want to see if the MAF is a restriction, watch the MAP pressure. When it starts the drop, there is a restriction somewhere. Could be runner, head, valve opening, plenum, TB, cold air intake or MAF. When all others have first been eliminated, then the MAF gets changed; removed, de-screened or replaced.
There are several, well respected tuners on this site that can help you. Send them a PM or start a thread in the tuning section, they will reply. Names that come to mind are JoeCar, FROST, Waitformeperformance......& several others. Good-luck
