Knock Sensor help
Old 08-14-2009, 09:30 PM
Gitano 1's Avatar
Default Knock Sensor help
I just bought both sensors to replace my bad ones, any good tuts on doing this?
will I also need to replace the harness as well?
Old 08-15-2009, 05:18 PM
PontiacChris's Avatar
I replaced both of my harness pigtails.They usally break when you try to disconnect them. Be careful that you don't break the oil pressure sensor when you take the intake off.
Old 08-15-2009, 05:19 PM
Pharcyde50's Avatar
I bought a new harness from the dealer when I did mine cause the orignal was falling apart. Make sure to torque the sensor to 15 ftlb and no more or you'll get false knock.
Old 08-15-2009, 06:42 PM
Oh and while you are under there you should TSB for them. I don't remember the number but they also say to make a silicone water dam in the shape of a horse shoe around it after installing it, 3/8 inch wide and 1/4 inch high with the open end of the horse shoe facing the rear of the engine. Also to remove and disgard the foam from under the intake manifold before installing it.
Old 08-15-2009, 10:14 PM
Gitano 1's Avatar
ah, thanks for the tips
since my stock intake is 11+ yrs old, any reason to replace the intake gasket?
I work at Carquest, so parts are cheap for me
Old 08-15-2009, 10:49 PM
KILLER-LS1's Avatar
yes get the harness, and yes, put silicon around the rubber seals. just watch out for the oil pressure sending unit, i kinda punched mine with my hand and broke it haha they are very brittle
