X pipe for shot torq arm??????
Old 08-22-2009, 06:54 PM
LSXFORMULA99's Avatar
Default X pipe for shot torq arm??????
i have a umi tunnel mount torq arm and was wandering what is the best x pipe for me. i know its not ganna be easy to make it work. Does anyone make something to have true duals or x pipe with tunnel mount torq arm
Old 08-22-2009, 07:58 PM
Hard Core Z28's Avatar
Dual x pipe systems with body mount torque arm wont work.
Old 08-23-2009, 03:38 PM
i thought they made a special one. i guess a bullet off the y pipe will have to work.
Old 08-23-2009, 03:52 PM
gyrene2003's Avatar
same baot here man, u would think something would have been able to have been designed after all these years.
Old 08-23-2009, 03:55 PM
SuperSlow02's Avatar
It can be done, BMR has a pic of one, but to give you an idea you would have to use something like the magnaflow xpipe and run the pipes along the single pipe route, or if your exhaust shop loves you they can get it to dump with a sharp 90/90 off the xpipe behinde the TQ arm cross member
Old 08-23-2009, 05:14 PM
SidewayzOZ's Avatar
Try fabbing up an H pipe instead. That was the only way I could keep my duals with the body mounted torque arm.
Old 08-23-2009, 06:03 PM
Monte LS....1's Avatar
Is the power gain worth all the trouble? how much power do you gain with an X compared to just true duals?
Old 08-23-2009, 10:43 PM
dumped y probably flows just as much as any....and i forgot to add the set up i described was for 3pt subframes
Old 08-24-2009, 05:34 PM
yeah im ganna try the dumped y pipe with a bullet. if it doesnt sound good, i will end up trying a h pipe or something. i just dont like my catback anymore. i miss the loudness of the x pipe
Old 08-26-2009, 03:41 AM
Pharcyde50's Avatar
I had to custom build my x pipe set up for my umi torque arm. I'm running 3" pipe with the x positioned in the middle of the torque arm chasis mount.
Old 08-26-2009, 09:24 AM
wrd1972's Avatar
Wrong. I did it with the Midwest body mount TA.
Pics in TD sticky.
https://ls1tech.com/forums/generatio...cs-too-30.html
Old 08-29-2009, 09:44 PM
thanks man
