What is the baddest sounding true dual setup?
I am thinking about going to true duals over my Hooker LT's ORP, and Loudmouth. I have Absolute Speed stage 2 5.3's and a 230/236 cam. I was wondering if the swap would be worth some HP and some bottom/mid range TQ?
A main concern is the sound. I have the Loudmouth now and it sounds badass with the heads and cam. The lope to the cam is awesome...very noticable...and nothing holding it back. I want to make sure that if I did it...the duals will perform...but also sound as sick at idle and all through the RPM range, especially wot, as the loudmouth did. I don't want the loud/lopey idle to be muffled if at all possible...want it to be as clear as day!!
So what do you think?? Will the duals add performance, and will it sound as ridiculous as the Loudmouth? I like the drag car volume!!! And the Pro Stock lope to the cam!!
What is going to give me the most power with big cubes...in terms of muffler selection. And what size pipe for big cubes 2.5-3.0???
What about for the time being...with just the heads and cam done?
You could try PM Blue2kSS he has a really nice setup. Its nice and calm in normal driving but its insane at WOT. Offaxis has a really nice setup too, there's a sound clip in the other true dual thread.
LS1TECH Sponsor
If you want the meanest sound I don't think I would do the X though.. I think the X tends to raise the pitch a little.
Pro stock johns car with straight pipes and 1 baffle mufflers sounded bad ***...
My car has an X pipe and has a little higher note to it.
