Race style LTs install?
I am getting the QTP Race LTs. I need to know what all I need to get for this install.
I know I need the EGR block off plate. Do I also need the Smog-pump tube Block-off plates?
I assume I need o2 extentions?
Should I get new gaskets and header bolts or just reuse the old ones?
The race style headers come with no hookups for the egr or air so your best bet is to just pull both systems out of the car, gives the engine bay a much cleaner look. Yes you will need o2 extension and o2 simms if you are not running cats, i would also get new gaskets and new bolts. The gm bolts are fine to use, but for a little bit more money and peace of mind you can get the stage 8 locking bolts, its all up to you.
