Oil Presure
Old 08-29-2009, 08:52 PM
rwta's Avatar
Default Oil Presure
My oil pressure gauge on my TA is at 45psi at idle then goes up to 75 psi at wot is this normal? It's a 2001 with 13k on her I only use mobel1 5w-30. I can't recall what it was doing last summer.
Old 08-29-2009, 11:42 PM
Zaxz28's Avatar
I've got a 2000 ls1 and mine reads 45-50 and warm idle it read 25 to 30 it has about 40000, yours seems a little high, sensor maybe?
Old 08-29-2009, 11:55 PM
twitchtwice's Avatar
Seems normal to me. Mine is a tick above 40 at idle and around the same as yours at wot. My car has 38k miles
Old 08-30-2009, 12:58 AM
2001taws6's Avatar
mine is right around 40 at warm idle and 60 or little more at wot. car has just under 110,000 miles.
Old 08-30-2009, 08:24 AM
01ssreda4's Avatar
Thats normal
Old 08-30-2009, 10:06 AM
Zaxz28's Avatar
Holy crap so what is wrong with mine!!!!!!
Old 08-30-2009, 11:34 AM
tag0398's Avatar
Zax, mine is just like yours and is a 2000 as well. It does go up to between 40 and 60 when I get on the gas though.
Old 08-30-2009, 05:59 PM
Zaxz28's Avatar
Thanks for the info man, I was getting worried.
Old 08-31-2009, 04:52 PM
tag0398's Avatar
I remember seeing it drop to 20ish the first time and getting a pit in my stomach. So I did some research and it seems to be well within GM spec for pressure. I still don't like it but I'm learning to live with it.
Old 08-31-2009, 10:32 PM
dwfronk's Avatar
a friend who has a 94 camaro and at idle he only runs 6 psi (his car is stock and a factor freak) he has replaced oil sending unit and has put a manual gauge on it to check it because he thought his factory one was broken. It is his daily driver and has been driving it like this for a few years and it still runs like a top.
I dont know what his oil psi dose when he gets on it but he said it dose go up. And buy factory freak i mean he runs better times then any other factor LT1 car.
