What size mm is a ls6 intake front opening?
Old 09-06-2009, 05:33 PM
nosaj's Avatar
Default What size mm is a ls6 intake front opening?
What size is a ls6 intake opening to compare to a tb? I was like the nx throttle body but it is a 85mm.
Old 09-06-2009, 05:40 PM
ttranssam's Avatar
78mm they can be taken out to 80 but id pay someone, im pretty sure that the nx will have an adapter plate
Old 09-06-2009, 06:46 PM
nosaj's Avatar
Appreciate it.
Old 09-06-2009, 07:24 PM
nosaj's Avatar
Has any of you used the NX throttle body. I was thinking about going with the 85mm SLP maf and the NX 85mm throttle body and use the adaptor plate to reduce it back down to the intake. Any thoughts?
Old 09-07-2009, 12:42 AM
bongva's Avatar
i have an 85mm tb and also use the reducer plate, dont have any problems at all
Old 09-07-2009, 03:18 AM
nosaj's Avatar
You see any throttle response, torque loss or anything?
Quick Reply: What size mm is a ls6 intake front opening?
