160 thermostat
Old 09-10-2009, 09:27 PM
shepss217's Avatar
Default 160 thermostat
i was wondering if putting a 160 thermostat in my 02 z28 would stop the pinging when i'm running it at the track. i run nothing but shell 93 and sunoco 93 octane, don't know what else to do, can anyone help me?
Old 09-11-2009, 01:13 AM
rich Z's Avatar
Things to try first. 1- Clean the maf sensor. 2- Get a can of Seafoam do to a topend engine cleaning. 3- Change your fuel filter. A 160 will help but you need a fan switch to turn the fans on when you sitting.
Old 09-11-2009, 05:37 AM
teke184's Avatar
it MIGHT drop the temps enough to stop it. but its kindda a bandaid for a bigger problem.
Old 09-11-2009, 05:48 AM
alottaboost's Avatar
Yeah, I'd have your car logged/tuned to help remedy the problem.
Old 09-11-2009, 06:31 AM
davidws6's Avatar
Default Pinging
+1 on a topend cleaning .
If it pings too much = it may self destruct !
The 160 stat may help a little but prolly not worth it. A can or two of Top engine cleaner would sure cost less, and would probably solve the problem.
Old 09-11-2009, 06:54 AM
SweetS10V8's Avatar
I wouldnt put a 160 stat in anything!!! 180 is as low as I would go.
