ATI Dampner
Old 09-11-2009, 09:18 PM
Bobs-00-SS's Avatar
Default ATI Dampner
I was wondering does ATI make different "grades" of dampners for LS1's? Also do they make different Underdrive percentages? Just wanting to make sure I get the right one, thanks!
Old 09-11-2009, 09:33 PM
405HP_Z06's Avatar
They make a standard diameter, 10%, and 25% under drive. The only other real difference is the durometer of the rubber used when assembled. I wouldn't use the 25%, they don't dampen enough for an LS1.
Get the 10% under drive with the standard durometer rubber and you'll be great. Also, CC Performance (Sponsor) has great prices on ATI.
Old 09-12-2009, 06:31 PM
airforcemanss's Avatar
^what he said
does anyone know if you need a custom or different ati dampner for someone thats running an 8rib setup for a procharger? i know they come standard with a 6rib so will i be fine or not? sorry for the hijack
Old 09-12-2009, 06:52 PM
405HP_Z06's Avatar
Originally Posted by airforcemanss
If all the other pulley's are 8-rib, than you need an 8-rib damper. ATI makes an 8-rib damper for this application.
