blow header gasket what is the best to replace it?
Old 09-18-2009, 10:28 AM
ajracing81's Avatar
Default blow header gasket what is the best to replace it?
So i just installed flowtech headers and remflex gaskets. Drove it hard for a week and checked the bolts a couple of times. Go to get it tuned and run on the dyno yesterday and blow out driveside gasket. I thought this may happen because of the surface on the header werent perfect when they were made so i dont know what to use im thinking stock because when we put them up to the haeder they looked like they would work. So any ideas and also what r u paying for stock gaskets i checked they wanted $42 for the drivers side?
Old 09-18-2009, 10:35 AM
LSX Mechanic
Damian's Avatar
The ONLY gaskets I use are the GM MLS manifold gaskets. Accept no substitutes.
Old 09-18-2009, 10:37 AM
Customizing Director
MadIceV8's Avatar
A pair should run about $23-30 from the sponsors.
Old 09-18-2009, 10:39 AM
ajracing81's Avatar
who should i go through?
Old 09-18-2009, 10:49 AM
ajracing81's Avatar
[QUOTE=Damian;12239397]The ONLY gaskets I use are the GM MLS manifold gaskets. Accept no substitutes.[/QUOT
do these have a wide contact surface around the openings because they wernt a perfect circle?
Old 09-18-2009, 04:22 PM
ajracing81's Avatar
is this what everyone is running?
Old 09-18-2009, 04:46 PM
69LT1Bird's Avatar
Heck ya, 7000 miles and no leaks and never had to retorque.
Old 09-18-2009, 11:52 PM
Frost's Avatar
This is good advice!
