FAST 78mm intake converted to 90mm?
Old 09-20-2009, 12:53 PM
Nick-lt1's Avatar
Default FAST 78mm intake converted to 90mm?
Someone told me that a fast 78 could be converted to a 90mm if you bought the 90mm upper? Is the true? Thanks
Old 09-20-2009, 02:56 PM
sscamaro1384's Avatar
as far as i know and have read it is true thats why the upper shell is over 400 dollars new but ive seen them on here and ebay for like 150-200. i have the 78mm and will be doing this when i add heads/cam. u also need the 90mm Tb to maximize power gains.
Old 09-20-2009, 04:43 PM
NAAllTheWay's Avatar
anyone know if the rest of the intake is identical tho other than the top shells?
Old 09-20-2009, 10:31 PM
DrkPhx's Avatar
You only need the upper shell to convert it, the lower shell is the same. You should also get a new gasket that seals them together as well.
