Pinpointing leaking fuel injector
I am working on my brother's car. He has a 2002 c5. The car cranks fine but doesn't start right away when warm. No issues otherwise.
After much troubleshooting, I have good reason to believe that an injector slowly leaks after the car is shut off. How would I go about pinpointing which injector is leaking? Any help is appreciated.
thanks
Joe
thanks
Joe
Unbolt the fuel rail and lift it out of the intake with the fuel line still connected. Turn the
key to the on position and the fuel pump will prime. See which one is dripping.
Moderator
Try moving the IAT sensor out of the engine bay. That (heat
soak) seems to be a real problem. If it will hot-start immediately
after parking, but not after park and sit for 15 minutes, that's
your pony.
your pony.
I had the same issue and it turned out to be the fuel pump. The check valve in it stopped working properly and it would not hold pressure when the car was off. Not sure if the vette pump is the same way but I would guess it is.
If you can get a fuel pressure gauge on the rail, and have rubber connection hoses, crimp off the pressure hose and watch the pressure. If it drops, leaky injector. If not you'll have to crimp at the fuel regulator return / filter inlet, both lines. Pressure drop on removing the return crimp = bad regulator. Drop on removing the feed line = bad check valve in pump. I have had to warm up injectors (with a hair dryer) with the fuel rail out to find an injector that only leaked warm.
