SLP LM+Corsa Clones
SLP LM+Corsa Clones
I wanted to know if anyone has installed a set of the corsa clone tips on their SLP LM1/2 exhaust kits and how it fit. Im not quite sure how the LM kits look as far as the piping goes. For example in order to install the corsa clones on a magnaflow kit one would have to remove those cannon tips and then add a section of straight piping to replace where the giant tip was and run it to the back of the car, than install the tips.
Anyone with pictures please?
Flarin Afro-Did you have to add some pipes in place of the SLP tips after your removed them or?
^well, the tips i bought were same size as exhaust so the place I had install them maybe used some kind of coupler? i will check in like 30 or so to see if they just welded it and get back to you. But, the newer ones now have a bigger inlet im pretty sure. Mine were 2.5 outer diameter at inlet.
the slp stick out further than the bumper thopugh im pretty sure, and i dont think there was much of a difference if i remember right. its been raining but i'll try to check tomorrow morning. you could also pm the ebay seller asking the length to make sure...
