how to hook up oil pressure gauge
Old 09-27-2009, 01:01 PM
txh0tb0i972's Avatar
Default how to hook up oil pressure gauge
ok im very limited to the search because im on my phone .... so i tried my best but i cant find what im looking for .... i have a 02 ls1 in my camaro and im trying to see how the heck i make my elec. oil pressure gauge work.... any help will be appreciated thanks!!!!
Old 09-27-2009, 07:10 PM
DopeFedZ's Avatar
With the sending unit that came with my autometer gauge I pulled off the cap right above the oil filter (two 10mm bolts) and drilled through the round indentation at the top of it. I then tapped that driilled hole for a 1/8npt thread and screwed the sending unit right into that. Install the cap back in its place and run your wire to the sending unit and your done.
Old 09-28-2009, 01:16 PM
SweeTbone's Avatar
DopeFedZ, do you have longtubes and did the sender clear the headers with any 45* elbows or anything else? Thanks.
Old 09-28-2009, 01:26 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I put mine inplace of the factory sending unit
Quick Reply: how to hook up oil pressure gauge
