Is there enough room for this setup
Is there enough room between where the Y pipe converges and where the exhaust has to bend for a 13" long Catalytic Converter, a 16.5" Bullet, and a 12" long turn down (which I'm sure could be cut down if needed)?
While I'm at it, is there a point in having a bullet if the cat is going to be there?
bigger question is will the cat function being so far down current.
and how much will it be choking the engine by only having one.
but to answer your question...on my ypipe setup there would BARELY be enough room i think. that's 42" of tubing...3.5ft.
it would be close
it would be close
