A couple of questions on manifold swap
Hey guys about half way through my swap and I just ran into a few more road blocks. First when converting to LS6 air bleed coolant lines and the block offs in the back, Do you need the little shims that go between the block and the pipe? Second, I am using a Weiand, (I know ls6 is better) I am using the felpro seal o print gaskets, can I use RTV on the block side and let it tack up to stop it from sliding?
Any help would be appreciated
Zach
Zach
Not second guessing you, just making sure I gave all of the information. I forgot to mention that my replacement ls6 pipes had o rings on them, so that would make 2 sets of o rings on one plug. Still necessary?
They look like these..http://cgi.ebay.com/ebaymotors/Corve...Q5fAccessories
Once again just making sure
Thanks man, It was just a big pain in the a$$ to get that manifold off, I just don't want to get it all hooked up and have leaks everywhere. First time want to do it right even if it means asking stupid questions.
