PCV system heat
Old 10-12-2009, 02:50 PM
Peppershaker's Avatar
Question PCV system heat
Just curious if any one else has thuoght of this. How hot is the air temp that is being sucked into the intake through thr PCV system. I live in Florida and regularly see intake air temps in the low 100's. If you say possible the air or gas your sucking into the manifold could be hot as the oil temp or even alittle lower would stil be around 200* How much could this be hurting performance be as this air isn't being monitored or detected by any sensor so the computer isn't making any changes for it. Does any one have any idea on some way to cool this air down. Don't want to remove the PCV system as it does perform a vital function.
