Can I use a LQ4 Engine in my LS1 car?
Old 10-14-2009, 08:19 PM
ferrari360man's Avatar
Default Can I use a LQ4 Engine in my LS1 car?
We need a motor, and I have quick access to the LQ4. I have some z06 heads in the garage, and a ls1 cam I could put in it. What would I need to do to make this work?
Old 10-14-2009, 08:24 PM
RPILS1's Avatar
lq4 and the ls1 are gen 3 engines all mounting points are the sames as well as trans bolting up heads will drop on grab a ls6 intake and enjoy i belive the covers and sensors will work with the lq4 as long as its has a 24x reluctor on the crank
Old 10-14-2009, 09:56 PM
OUTLWZ's Avatar
Yes you can..
Direct swap. You will need to use the LS1 intake, windage tray, pick-up tube and oilpan. Plus your front accessories.
Old 10-14-2009, 10:05 PM
windage tray?
Old 10-14-2009, 10:09 PM
OUTLWZ's Avatar
Originally Posted by ferrari360man
windage tray?
The tray that sits under the crank. Its different on the LQ4, because of the different shaped oil pick-up tube.
Old 10-14-2009, 10:11 PM
DutchmanZ's Avatar
The windage tray is inside the oil pan. And yes it is an easy swap and provides that nice torque that some LS1's don't have.
Old 10-14-2009, 10:29 PM
alright what abt the accessories?
Old 10-14-2009, 10:33 PM
OUTLWZ's Avatar
You will have to use your stock waterpump, alt, p/s, and idlers & tensioners.
Basicly the longblocks are the same.
Old 10-14-2009, 10:35 PM
nitr0racing21's Avatar
pick up tube?
Old 10-14-2009, 10:36 PM
OUTLWZ's Avatar
Originally Posted by nitr0racing21
pick up tube?
The oil pick-up tube. The long tube that runs off your oil pump with the screen on the other end.
Old 10-15-2009, 01:06 PM
just to be sure, what year lq4 truck should I get this from or does it not matter? I would like to get the most power out of it as I can so I can keep similiar power to what the stock vette had.
Old 10-15-2009, 01:09 PM
can I put the ls1 heads and cam in this for some power gains or should I leave it the way it is and do exhaust and intake?
Old 10-15-2009, 07:04 PM
OUTLWZ's Avatar
If I remember right you want a 2001+, the older 6.0's had a spacer on the crank that wont work with 4l60e. And in 04+ the LQ4's got the same rod and rod bolts as the LQ9's.
Which heads do you have?
If they are 243 heads then you would want to use them. I debated about using my stock 241 heads for the comp but decided to use the 317 heads for the better flow.
With the stock LS1 vs. LQ4 cams, you wouldnt really be able to tell a differnce between the two.
F-Body cams-
98-00 LS1- 198/209 .500/.500 119.5LSA
01-02 LS1- 196/207 .467/.479 116LSA
Truck cams-
01+LQ4/9- 196/207 .467/.479 116LSA
Old 10-15-2009, 09:05 PM
the lq4 motor is a 6.0 or 5.3?
Old 10-15-2009, 09:19 PM
plum krazy's Avatar
6.0. i did the swap to my camaro it aint nothing to put in. but i bored my block .30 over easy swap
Old 10-16-2009, 01:30 PM
eek, the motor i Have is not the lq4 then, we have a 5.3 liter in the garage. I thought I read somewhere that the motor could be made to work in place of the 5.7
Old 10-16-2009, 07:56 PM
OUTLWZ's Avatar
The LQ4 is a 6.0L
I wouldnt put a 5.3 in my car, why go smaller
Old 10-16-2009, 07:57 PM
Originally Posted by OUTLWZ
The LQ4 is a 6.0L
I would if I was building a boost beast or if you want a lighter car the 5.3 I THINK is a aluminum block
Old 10-16-2009, 08:40 PM
123clemans's Avatar
if u got to bye a motor why not lq9
Old 10-17-2009, 01:11 PM
gnasty1521's Avatar
LQ9's are the same except for dished pistons I believe. They only came in high end caddilac's and some H2's. They are very rare, and thus, are more expensive. Either way, most people change out the cam anyways so LQ9's are not that much better at all.
Someone please correct me if I am wrong...
Quick Reply: Can I use a LQ4 Engine in my LS1 car?
