2.5'' dual setup, better then 3''y with 2.5'' tail pipes
Old 10-25-2009, 08:02 PM
themack56's Avatar
Default 2.5'' dual setup, better then 3''y with 2.5'' tail pipes
im planning on an over the axle dual setup. my question is, does a 2.5'' all the way from the x pipe to the tail pipes flow enough? comparable to a3'' y pipe with 2.5'' tail pipes? my guess is that it does flow better, any input. and yes i searched but i couldnt find any answer to my particular question.
Old 10-25-2009, 09:17 PM
jimmypop13's Avatar
Yes, they will flow better than one 3". Run a search for David Vizard. You will find lots of exhaust info and some quotes from his book that say how much different size pipes can flow
Old 10-26-2009, 07:20 AM
teke184's Avatar
just look at the crosse sectional area:
single 3" = 7.07 sq inches
dual 2.5" = 9.82 sq inches
28% increase
Old 10-26-2009, 08:48 AM
LS1W66's Avatar
https://ls1tech.com/forums/2987587-post19.html
Old 10-26-2009, 03:34 PM
King Nothing's Avatar
yes it will! but you'll also gain abit more from having them run under the axle as opposed to over the axle . . . unless your planning on running cut-outs in which case wont matter
Old 10-28-2009, 09:10 AM
kkslds's Avatar
Is it gonna be manderal bent or crush bends? That will make a difference comparing to a manderal bent 3" y
Old 10-28-2009, 09:20 AM
themack56's Avatar
mandrel
