Alternator Relocation Question
Does anyone know what alternator will fit the speed inc alternator relocation bracket? Its a smaller alternator with higher amps and I've tried doing searches with no luck. Trying to avoid the 180 dollar price tag when a standard ls1 alternator is 90 bucks. It looks like a regular GM alternator, maybe someone knows one that will fit???? Thanks in advance
Well just in case anyone was wondering you can modify your stock alternator to work with these brackets. Just have to remove the clip on dust guard on the back, grind down the front a little bit and open up the hole on the alt a little bit also. It fits tight now and I'll let you know how it runs when its all together!
