ASP Pulley eating belts
Old 12-07-2003, 10:06 PM
Venkman's Avatar
Default ASP Pulley eating belts
Anybody had the belt jump over a tooth and shred after the ASP pulley intstall? Any ideas on how to ensure this doesnt happen again?
Old 12-07-2003, 10:39 PM
SMOKIN01TA's Avatar
maby the belt is to big and the pulley isnt puting enough tension on it
never had any problems with mine
Old 12-08-2003, 11:33 AM
big dave's Avatar
I believe GMHTP magazine had the same problem when they did their bolton article. I think they said they had to replace the tensioner. I think you may need a different sized belt.
Old 12-08-2003, 11:38 AM
v8maro's Avatar
is the pully sitting on the crank the right way?
-Steve
Old 12-08-2003, 11:47 AM
SSCamaro99_3's Avatar
I had this exact problem. I got in there with a straight edge, and it looked like the alternator pulley was out of line. We removed the ASP alternator pulley, and put it on a flat surface next to the stock pulley, it was one rib to tall. It was throwing the belt about every 50 miles or less, and chewed up one edge of it.
Old 12-08-2003, 06:32 PM
WILWAXU's Avatar
Make sure that ASp pulley is seated correctly...
Old 12-09-2003, 12:43 AM
Krab's Avatar
If nothing is wrong with the pulley being seated properly, and you have the right belts on there, it's probably your tensioner pulley. Buy a Larry pulley with a taller lip and it should stop your belt throwing woes.
Old 12-09-2003, 02:15 AM
Venkman's Avatar
Whats a larry pulley gonna cost me?
Old 12-09-2003, 04:16 PM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
I had same prob. w/ 2 sources of prob.
1. - thrown belt - ASP pulley loosened
-Pulley reinstalled correctly
2. Belt thrown again - Stock belt tensioner replaced (I used a new stocker, but Katech highly recommended).
Probs gone.
Old 12-09-2003, 06:52 PM
Nasty N8's Avatar
Replace tentioner either with a stock or a Katech.
Nate
Old 12-10-2003, 05:56 AM
Smoke_Ford's Avatar
Make sure the pulley is seated properly. In addition, make sure the crankshaft seal is also seated properly to ensure that the pulley can be seated properly...
