Dyno before and after QTP longtubes and Y?
Old 10-31-2009, 01:32 AM
Brian'sCharlotte(TA)'s Avatar
Default Dyno before and after QTP longtubes and Y?
I just bought some and was wondering if anyone had had a few runs before and after so I could see the power gain. I plan on doing mine, i'm just curious
Old 10-31-2009, 07:36 AM
StreetGliderX's Avatar
i doin an Lpp swap on mine and i dontr have a base for comparo but i will have it dynoed out for tunin prob next week
Old 10-31-2009, 08:53 AM
Taylor1969's Avatar
most longtubes and y net like 20-30 hp. brands wont really make a difference.
Old 10-31-2009, 10:09 PM
for the trouble they are to install they should be 100hp
Old 11-01-2009, 12:27 AM
Yeah I havent started yet. I'm waiting on my Strano's to get here so I can do it all in one swing. My friend just put his TSP's on and he said it was a pain. no fabrication though he said his bolted right up. I'm hoping for the same luck
Old 11-01-2009, 07:16 AM
dear god i hope so man please let me know.... mine will soon fit so there will be no need to remove them....
Old 11-01-2009, 07:46 AM
Bo White's Avatar
Its not too hard comparitively speaking to other vehicles but then again I worked at a muffler shop for years and done header swaps on alot of vehicles. I even got to lookin forward to doing swaps on LT1 cars compared to some of em.
Old 11-01-2009, 11:59 AM
kinglt-1's Avatar
Just plan on two 8hr days installing the headers. It should only take a day, but if you run into troubles at some point, you can walk away and continue later on. this works for me because I don't work well when Im pissed off lol. It's not that difficult of a install, you just need alot of patience!
Old 11-01-2009, 12:24 PM
95maroz28's Avatar
i just did a set of slps and from what ive read they are almost if not the worst to install. Wasnt too bad but did take a couple days with trial and error. Good luck on your install and remove the plugs. i cracked three trying to get the headers up in place.
Old 11-01-2009, 02:36 PM
well mine fit like a saddle on a sow so i gotta remove the driver side and do some massagin to get rid of the vibes
Old 11-01-2009, 02:51 PM
ls1curt's Avatar
i didnt think they were as hard as everbody on here was saying. i did them in about 8 hours total
Old 11-01-2009, 07:14 PM
1979rs/z28's Avatar
X2 By myself on the ground. BTW they were pacesetters though.
Old 11-02-2009, 01:26 AM
Damn.
Old 11-02-2009, 01:28 AM
Anyone have any experience with a spring install? I'm raising mine up from the sportline drop to the Strano's whenever i get them (hopefully soon). Just wondering how difficult it will be.
Old 11-02-2009, 01:51 AM
camcamaro1991's Avatar
Default Headers.
Apparently none of you guys have installed longtubes on a 3rd gen
4th gens are super easy. i had a lift & air tools at my shop it only took 3 hours for full header install minus the engine mounts.
i would highly recommend you install some poly or solid engine mounts before you install the longtube headers, its also a good time to install new spark plugs and wires if you got them, i installed new GM exhaust gaskets they work great. yes i have installed spings on 4 gens. you will need a good spring compressor tool and a alignment after the front springs are installed.
i had the the SLP suspension package, and installed koni 4/4 and Strano springs, and man it was a world of difference, so it was already about the same ride height but still needed a alignment and PHR for the rear.
good luck
