lingenfelter 2 step causing car not to run
On my way to school this morning I stopped at Hardee's to grab some breakfast, walk back to my car go to crank it and it just turned over. finally it fired but then immediately died. my buddy showed up and watching a coil to see if spark would jump across one of the plug wires and it wouldnt. so i unplug the two step and bam car cranks and runs fine. has anyone had this problem so far, or any ideas on what might cause this?
probably just some moisture got there. try putting dialectic grease on the connections. it helps keep moisture out, you could also try spraying wd-40 around the area.
LS1Tech Sponsor
LNC start up problem
Is your LNC working ok now? I have never heard of any customers having problems with our 2-step due to wate/normal washing (although we do warn against using a power washer for cleaning under the hood as this can hurt all kinds of things).
Feel free to contact us directly if this problem continues.
I also had a problem, no power, stuttering but as soon as you would unplug it run just fine. So after a few phone calls we decided it was ran to close to the coil packs so we rewired it more to the front of the car and haven't had any problems since.
