how hard is it to replace oil pan gasket?
Old 11-04-2009, 08:23 PM
Brianbanscak's Avatar
Default how hard is it to replace oil pan gasket?
Looking at replacing motor mounts soon, just wondering if the oil pan gasket can be replaced without too much work while doing the mounts? Or does the motor need to be pulled?
Old 11-04-2009, 08:59 PM
XtremeDime's Avatar
Well if youre doing mounts youre going to need to pull the engine up a little bit anyway you only need a few inches of space to drop the pan.
Old 11-05-2009, 11:22 AM
klujan13's Avatar
If you are doing the motor mounts then I strongly suggest doing the oil pan gasket at the same time. You will be lifting the motor up slighty when you change out the clamshells and that is the perfect time to drop the pan. I read all the horror stories about dropping the oil pan but it seemed pretty simple for me once I had the mounts off.
Old 11-05-2009, 12:06 PM
DarkJuggalo's Avatar
i would just do it while your there, unless you plan on doing a cam soon. you gotta drop the pan to do the oil pump/timing chain. so it all depends on your intentions
Old 11-05-2009, 07:08 PM
Do you need to drop the tranny to change out the oil pan gasket? How would you raise the motor if you can't use the oil pan as a lifting point? How much more time would you say it would take to do the oil pan once the motor mounts are out? Total time for the whole job without a lift? Any good manuals or online guides?
Old 11-05-2009, 07:15 PM
eseibel67's Avatar
Haven't done this on an LS1, but in the olden days, I used to lift the engine by the balancer.
Shop time for oil pan gasket is 4.5 hours complete, so it's probably a pretty big job.
Old 11-05-2009, 08:02 PM
XtremeDime's Avatar
I think Im gonna do this tonight....I have no accessories on the front of the motor and I need to pull the oil pan also. Where can I lift from?
