loosing oil pressure
Old 11-21-2009, 03:55 PM
19trans_am98's Avatar
Default loosing oil pressure
ok this has happened twice now....after i run the 1/4 at my local track i have to get on the brakes pretty hard and it loses oil pressure...the last motor lost oil pressure and it needs bearings now... so i found another motor and replaced it and last night this motor did the same thing is there anyway to add some baffling in the stock pan to keep oil around the pickup or should i buy an aftermarket pan? thanks
Old 11-21-2009, 04:37 PM
Monte4ever's Avatar
Is this in your 79 Camaro? If so, what oil pan are you using?
Old 11-21-2009, 04:49 PM
nope in the trans am...and the 79 i am using the hummer oil pan
Old 11-29-2009, 04:23 PM
anyone?
Old 11-30-2009, 10:23 AM
01ssreda4's Avatar
Oil pan already has baffles. Maybe you can run an extra quart of oil.
Old 11-30-2009, 10:41 AM
horsepower_junkie's Avatar
I would put a oil accumulator on it if I were you. They work great in those situations. You can pick up a moroso from summit for 190. It holds an extra three quarts for when oil pressure drops below normal and will fill back up once pressure is normal again. Well worth the money to me.
Old 11-30-2009, 12:06 PM
ok thanks guys i have been running an extra quart but ill try the accumulator
