Searching for some more power past bolt-ons, heads/cam/intake
Done for the year. Ran my bests yesterday of 11.40@119 MPH on a 1.54 60'. So I really wanted 10's on motor but just too much weight. Maybe a 4k plus stall would have dropped me a little more. So does one of the large lid/MAF setups add much power? I need about 60 RWHP or so.
If I had to do it over I think I would have kept my 11.79 bolt-on car and added a supercharger to get me there. Other option at this point is Nitrous. Think things would hold up well on a 150 shot?
I have thought about a bigger cam. I don't know how much I can go though since I won't be able to fly-cut the pistons at this point. I have thin Cometics and 67cc chambers for 11:1 compression plus 2.05 intake valves. Figuring what size cam I can stuff without PTV issues is harder now.
The converter would be nice but I drive the car alot. Trips to the beach, out and about, etc... I think I want to keep what I have there.
One other thought is full slicks instead of DR's next year but don't know how much that would gain.
If you're not willing to take about 400 lbs out of that thing, then it's never going to run 10's without a very aggressive H/C package. A restall to 4200 would help to get that pig moving too. If you just want to run a 10 sec number, just throw on a 75-100 shot and you'll be there no sweat. I'd say the only thing you'd have to worry about breaking with that setup would be your tranny. The motor should be fine as long as the tune is solid. And if you're not spinning at all on the launch, then there's no reason to go to slicks over DR's other than the weight savings.
A low 1.5x will go 10s if you can get the rest done at the other end. You'll need another 2-3mph. I've said it before, that setup is just too mild for 10s full weight. Either drop several hundred pounds, or go bigger on the cam and converter.
You could gamble with some truck coils , an electric waterpump, and either an 85mm intake setup or speed density tune. Then drop the front sway bar and pull the seats. It might work...
Something still isn't right you only gained 4 mph with patriot heads, fast 90 and a cam. Things are just not adding up at all. I would yank that cam and throw one in there with some real lift. Lift is not going to affect your piston to valve clearance like more duration will. It's a pretty mismatched combo really. Big valve heads, big combustion chambers, small cam, and a fast 90. Doesn't make much sense.
get a ram air on there...25rwhp or 2.5mph...pm if you want one...
https://ls1tech.com/forums/generatio...lts-tom-2.html
check post 23...also last posts show the new black finished product
