LS7 flywheel and clutch On LS1???
I bought a barely used Ls7 clutch and flywheel from Katech for what I think was a good deal, I thought I had read I could use a Ls7 clutch as a stock upgrade however when I went to the GM dealer today to order Flywheel and clutch bolts, I also wanted to order a pilot bearing, this may sound like a dumb question but the LS7 and LS1 part numbers are diffrent? they are diffrent sizes. will this set up work or should I just look for a Ls6 clutch? thanks!
LS1Tech Sponsor
the parts you need are as follows.
GM LS2/7 flywheel
GM LS7 clutch (includes clutch disc and pressure plate)
attaching bolts (if you want) for flywheel and pressure plate
pilot bearing # 14061685
slave cyl that fits YOUR VEHICLE or the vehicle you took it out of. i assume you are using an Fbody T56 so that is the pilot bearing for the fbody T56. if it is from another vehicle, please let me know.
no offense to the rest, but most gm dealers do not know the diff. they only talk in part numbers and they only know what the computer tells them. they do not know the difference.
GM LS2/7 flywheel
