solid motor mounts by sphon
Old 12-15-2009, 07:17 PM
kentuck's Avatar
Default solid motor mounts by sphon
has anyone had trouble with the tube type mounts from spohn when i put them on my 2002 camaro it raises the motor 1 inch or and headers are pin against the floor board thanks for any help
Old 12-15-2009, 07:33 PM
onebadazzls1ta's Avatar
Never had a problem but then again I'm not on lt's I do however have a problem with the engine mount bolts comming loose
Old 12-16-2009, 10:15 AM
dgcustomz's Avatar
I had the same problem when I first installed them when I had hooker headers. My driver side header was hitting my floor board. I had to heat up the header collector and bend it down a little bit. The added benefit to me was that it gave me better oil pan clearance. I had broken one before after my sportline drop kit and now that it raised up the engine I had no more problems. Well, Before I sold that car I removed them and installed them on my other z28 and I installed kooks headers and had no issues with the floor boards. I guess it's the brand of header you buy. As for the bolts coming loose I have never had this problem as I tighten the crap out of them. I do love the added reaction of the car and especially after I went with the poly trans mount.
Old 12-16-2009, 06:31 PM
madhatter's Avatar
No problems on the set I installed a few weeks back. They are Grot headers though. I highly recommend using loctite on all the bolts as well.
Old 12-17-2009, 01:52 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
No issues here with my solid mounts and Pacesetters
Old 12-18-2009, 12:08 PM
a98ws6's Avatar
I don't understand why they would make these to raise the motor at all? I have these and have not installed my motor yet. I am getting ready to buy headers soon and don't know which ones to buy if I'm going to have clearance issues???
Old 12-19-2009, 10:34 PM
PUNISHER TA's Avatar
I have Kooks 2" w/ 3-1/2" collectors...
I plan on getting these for my new motor...
Ive never heard about these raising the motor... WTH?
Does it in fact raise the motor?
Old 12-19-2009, 10:51 PM
198esp's Avatar
no problems with qtp's ,stood the stock ones next to the solids they were the same hight.
Old 12-19-2009, 11:06 PM
Grifter's Avatar
I have Spohn's and Grot's. I do believe it raised the driverside slightly but it didn't effect anything.
Old 12-19-2009, 11:28 PM
SS4Luck's Avatar
it does raise the motor an inch, i believe it even says it on the spohn website... the only header ive heard that have problems are the Hookers. My pacesetters and TSP headers were fine with them
Old 12-20-2009, 12:38 AM
VeTTeMaNC486's Avatar
I don't see why anyone would want the motor raised unless the car is lowered or something. Its a pain in the *** enough to work on under the cowl as it is. Plus raising the center of gravity... Seems odd? Someone enlighten me please?
Old 12-20-2009, 08:20 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I didnt have a problem with FLP's when I put a set in.
Old 03-24-2010, 03:34 AM
kmracer's Avatar
no problem with kooks.
Old 03-24-2010, 07:43 AM
TheSilverOne's Avatar
no problem with QTPs
Old 03-25-2010, 11:05 AM
sjsingle1's Avatar
i have the NOT solid spohn mounts.......with the polys it does sit higher.......so much so that the header is a tight fit on floor pan......spohn said that their mounts are stock height
Old 03-25-2010, 11:20 AM
blk99sleekbeak's Avatar
i wish i had put solid mounts in my car when i did the headers
Old 03-25-2010, 11:40 AM
FST SS's Avatar
that's when I put mine on
Old 03-25-2010, 12:48 PM
x2
Old 04-09-2010, 09:43 AM
emolineaux's Avatar
i didnt see a diff. in height when i installed my solids. they were slightly taller when i stood them next to eachother but thats also because the stock mounts were pretty worn out. so they should be same height as stockers would be when they are brand new.
i have tsp headers and they fit fine. only time the hit the floor a little was when i had the lift the motor to get the driver side mount it.
Old 04-10-2010, 08:12 PM
105's Avatar
Are these the spohn mounts I need?
http://speed-eng.com/store/spohn-tub...ts-p-3038.html
I'm having problems with my LPP header on the driver side hitting the motor mount and preventing me from lining up the bolts.
Quick Reply: solid motor mounts by sphon
