My LPP header and TDs install, Pics & Video
Well the headers and TDs are on the way. Should be here Tues.
So far the removal of my SLP headers and Y-pipe has ben lots of fun (Scarcasm). Cutting out the Borla catback took all of about 3 hours. Had to use 2 sawjazal blades and a dremel to cut the 3" tubing. The y and cats came off fairly easy with some help from block of wood and BAH.
On to the headers. This was a bundle of joy. Started removing the passenger side header last night. Got all the bolts out except for one. Rounded it off. So today went to get some bolt extractor sockets, well they didn't work either, imagine that. So had to bring out the ole dremel and grind that F'er off. After about 30 minuets of grinding finally got it out.
So now start the removal of the header. I must have fought with that damn passenger side header for 2 hours. First had to remove starter, that got it a little closer to coming out. So then decided to lower k memeber on that side. So lowered a little bit and low and behold the F'in header is now wedged between the k-member and the inner fender. Could budge that sucker. So am thinking what now, so tried dropping the k-member some more and it freed it up. But to know dramatic ending finally got the SOB out after dropping the k-member all the way and working it just right, slid right out (scarcasm). Felt like crying once it fell out. Now on to the driver's side, Yeepy! God I hope the LPP go in alot easier. Will be postig picks off the install and a video. Have only seen one video of this setup, am sure people are curious to the sound.
Sorry you had so much trouble getting them out. If it makes you feel any better, you could just buy a Vette and do the entire job from start to finish in around 3 hours.
3 hrs to do what? Took me several hours to get my headers and xpipe on. Didn't have access to a lift though.
Done it in 3 hours on jackstands.....it's fairly simple. Course....I've done a few of them so I know the fastest way, and all the sizes of sockets and what not. lol
Please tell me you're not taking them out from the top. If so, you're making a mountain out of a molehill. The LPPs slide in nicely from the bottom just be sure to put the jack with a block of wood under the collector on the drivers side after you get the bolts started. Put some pressure on the header and tighten the bolts up the rest of the way.
Here is some info on my LPP headers I installed. If you want any more info, let me know. I would get them again, fit great now.
https://ls1tech.com/forums/generatio...some-pics.html
Well after laying under the car the last 2 days install the motor mounts, headers and TDs it looks like everything is going to work pretty well. The install went pretty smooth except for all the grinding I had to do to get the stock clam shells apart and the grinding on the k-member and drivers side motor mount for the header to fit. Really didn't have to take out that much material just tried to do it a little at a time, and had to take the header out about 5-6 times before finally getting it to fit without touching anything. Passenger header went in easily with the starter and k-member dropped on that side. Don't have everything buttoned up on the TDs but got to fire it up and it sounded good. Not near as loud as my catted y with Borla fully open. Got pics and will post up soon. Man that stainless looks good.
Here are a few pics of the Headers and TDs system. One thing to point out is that even though this is a Catless system there are rear O2 bungs welded in for either a Wideband or if you have cats installed. Thought that was nice. Don't have real great pics of everything installed. They were taken in a hurry and am now out of town. Will get some better ones when everything is finished. Enjoy!
Do you have any exhaust leaks? I got the headers and y-pipe set up from them so it might be different but all the connections on my y-pipe had slits in the pipe so I had to use Accuseal clamps to get them leak free. The band clamps I had wouldn't seal tight enough on the smaller side to stop the leaks
