Oil fill tube removal. Am I stupid?
I tried this too when painting my valve covers. I said the hell with it and just taped them up and left them on bc they were being such a pain in the ***.
if you are removing it to install a breather do not do it !!! i removed my filler neck and installed the breather, and the breather kept dripping a little oil on the exhaust manifold because it is on an angle. if you keep the filler neck the breather will be straight and no leaks.
Thanks to all that chimed in. I just wanted to double check before i break somethin.
