How much hp?
How much hp?
I went to the shop to get dyno tuned, and found out my headers had big cracks in them, and the y pipe was rusted through, so the o2s were not getting a good reading. While I wait for the headers and y to get in what do you guys think it will put down? SLP lid, maf, smooth bellow, 85mm throttl body, 85 mm typhoon intake manifold, comp cam beehive springs(.640) lift, comp cams hardend pushrods, lunati voodoo cam .599 intake and.601 exhaust.
Stainless longtube headers, off road y pipe, and a borla cat back. Just looking for input to hold me over for about a month.
Here are the specs
Hydraulic roller. Serious street/strip cam for 5.7-6.0 liter engines. Requires computer modifications. Needs upgraded intake manifold, exhaust and aftermarket fully adjustable rocker arms to maximize performance.
•Advertised Duration (Int/Exh): 282/288
•Duration @ .050 (Int/Exh): 232/238
•Gross Valve Lift (Int/Exh): .599"/.601"
•LSA/ICL: 113/109
•Valve Lash (Int/Exh): Hyd/Hyd
•RPM Range: 2400-7000
•LSA/ICL: 113/109
