Need help on AIR removal on an 01 pics inside?
So I have removed the AIR pump, and blocked off both manifolds. There is what looked like a vaccuum valve behind intake attached to the d/s head and I have removed it and piping also. What vacuum connections need to be blocked off now. As the engine is going in fresh and I dont remember where the hoses went to start with. Seem like when I searched all the writeups skipped this step. Do I just block off the port right on back of the intake? Im talking about the 90 degree barb fitting directly on the back and center of intake.
Thanks
Thanks
i just capped off the line that went to the t or y that went on by the back of drivers head don't know where the other line goes
on my 01 all the lines converge at the valve behind intake I believe. Then one goes to intake just trying to refresh my memory
Here is what Im trying to remove. I believe the whole saucer shaped thing and all the lines can be removed then cap off the intake. And ditch the little solenoid since we dont need any of it . So can I remove 1,2,3,4,5? Then cap 6. Where does 7 run to?? Brake booster?
It looks like you have the info needed. Here is some info I found when asking the question.
https://ls1tech.com/forums/generatio...questions.html
