Make your own oil cap breather ~$20 *Guide*
Old 01-20-2010, 08:01 PM
Tyler valo's Avatar
Default Make your own oil cap breather ~$20 *Guide*
To try to reduce my oil consumption I decided to try running a breather instead of a PCV system. Most breathers are around $50 and seem very over priced so I decided to make my own, this can be done even cheaper if you decided to use you stock oil cap.
1. Go buy on of those small breathers at Advance Auto, Pep Boys, AutoZone, etc. They run around $12.
2. Napa carries replacement oil caps for most cars, mine ran $6.
3. This is the only real "hard part". You'll need to drill though the bottom of the cap up though the top. I set mine on a block of wood and held it with my feet. I used 3 bits, gradually stepping up to a 1/2" bit. Beyond that I used a dremel with one of those side moving drill bits to enlarge the hole, be sure to stop and check regularly. If you go large a bit of RTV can be used.
4. Heat up the rubber on the filter a bit with heat gun or hot water, then slip it into the oil cap and enjoy your 1/2 price breather.
Old 01-20-2010, 09:19 PM
Hamrdown's Avatar
Nice job and the Simpson's underwear in the floor is halarious and disturbing.
Old 01-20-2010, 09:31 PM
Dewman's Avatar
simpsons underwear, blanket and pokemon book
Old 01-20-2010, 09:37 PM
SweetS10V8's Avatar
You know how many people do this and leave there PCV systems on?? Haha...
I know you didnt, but its funny to see how many people dont see how its a vacuum leak.
Old 01-20-2010, 09:49 PM
Tyler valo's Avatar
Haha, well I'm only 23. Simpsons is my favorite show EVER and I have lapses where I'll bust out my Nintendo 64 and play classic games, Pokemon Stadium is one of my games.
Old 01-20-2010, 11:40 PM
Mart00SS's Avatar
matching simpsons blanket also
Old 01-20-2010, 11:44 PM
SSmokin99's Avatar
OMG this is hilarious! I have the SAME EXACT SIMPSON BOXERS!!! HAHAHAHAHA
Old 01-21-2010, 02:13 AM
blu byu EH's Avatar
Wow its kinda getting a little gay in here
On a different note great idea.
Old 01-21-2010, 02:17 AM
pheer's Avatar
N64 ftw
and apparently "birthdays are like boogers"...?
Old 01-21-2010, 03:53 AM
94'BLKBRD's Avatar
Good info.
Old 01-21-2010, 07:05 AM
teke184's Avatar
seems like a vacuum leak to me too.
then again i tried to discuss that on this thread about breathers and got blasted by Damian.
seems pretty obvious that it would cause a vacuum leak just like when i had a hole in my pcv line.
Old 01-21-2010, 07:12 AM
Tyler valo's Avatar
You don't run a breather and PCV together though (If you really wanna do it right). It's one or the other.
Old 01-21-2010, 09:47 PM
1999BlueTA's Avatar
Nice Info i'm going to delete my PCV also i'm going to be using one of those small breathers on each valve cover.
Old 01-21-2010, 10:13 PM
JFM-jr's Avatar
How is it a vaccume leak? The way I see that scenario the PCV system will have 2 sources to draw fresh air from. Thats not a vaccume leak if the entire PCV system is left intact.
Old 01-22-2010, 06:07 AM
JFM-jr's Avatar
just tto add to this a little. The PCV system draws a set volume of air thru it. The valve limits it so let's say as an example it draws 100cfm at an idle. That 100 CFM is being drawn thru the fresh air intake in the TB.if you added a breather it would in theory then pull 50 cfm thru the TB and 50 thru the newly added breather but the overall volume is a fixed amount.
Old 01-22-2010, 06:14 AM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Thumbs up
EXACTLY......
Old 01-22-2010, 06:30 AM
teke184's Avatar
if that is truely how the pcv valve works...then that explains it.
Old 01-22-2010, 06:41 AM
Internet Mechanic
BlackScreaminMachine's Avatar
The only other thing that I could have suggested was a nekkid chick spread eagle on the bed while your focusing on the shots for the parts.....
AFTICA's Avatar
This is what I was trying to say in the other thread. He just said it better I guess.
Old 01-22-2010, 06:03 PM
Tyler valo's Avatar
My girlfriend was on the bed at the time (you can see her foot in pic 2) but she wasn't naked
Quick Reply: Make your own oil cap breather ~$20 *Guide*
