FAST Intake and Coolant Rail Question
Old 01-21-2010, 05:31 AM
fjb78's Avatar
Default FAST Intake and Coolant Rail Question
I am in the process of doing a head, cam and intake swap. I thought I had a LS6 intake on my car. When I removed the intake the coolant rail is still there that goes from the front to back of the heads. Can the FAST intake be installed with this coolant rail? If not what do I need to do. Thanks for the help.
Old 01-21-2010, 06:19 AM
Engine_HP's Avatar
get the c5 zo6 coolant pipes or cut and weld the one u already have read here: http://www.ls1howto.com/index.php?article=5
Old 01-21-2010, 07:05 AM
SweetS10V8's Avatar
No you cant use them. The instructions tell you this, and tell you what part number to buy from GM.
Old 01-21-2010, 11:45 AM
fjb78's Avatar
I bought the manifold used and do not have the part numbers.
Does anyone have the numbers for me? Thanks
Old 01-21-2010, 12:14 PM
teke184's Avatar
most of the vendors sell the tubes....generally listed in the intake manifold section.
since you need them for the LS6 and the FAST swap
Old 01-21-2010, 04:22 PM
fjb78's Avatar
I ordered the kit from a sponser.
Thanks
Old 01-21-2010, 05:20 PM
garygnu's Avatar
you can run a coolant line under a ls6 intake ,just remove some of the ribs on the under side of the intake floor.if installing a fast intake get 2 vette coolant lines.use rubber lines to connect both to a T-fitting.or drill and tap the coolant passages coming out of the heads and run AN fittings and braided lines.
